EZ Lube Jiffy Lube in the Spotlight...Again
NBC channel 4 in LA is running yet an undercover expose on EZ Lube and Jiffy Lube lube centers. This time they are focused on engine, fuel injector, and transmission flushes. This link explains it all. Not sure the video will work for you but the narrative is there for all to read. The bottom line - don't let them tell you a "flush" is recomended or part of scheduled maintenance on your car. Manufacturers don't recommend them and some won't cover damages caused by them.
http://www.nbclosangeles.com/news/lo...hservices.html
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds. **Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual. 07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan |
Re: EZ Lube Jiffy Lube in the Spotlight...Again
my mom weny out to jiffy screw for oil change they replaced oil and oil filter my mom check level before left did approx 300 mile then knock knock got it to home called jiffy complain to manager he perrsonally came to house crawled under car removed filter with barehands blamed fram bad seal didnt mention filter wasnt tight and they made a mistake cost her 1300 for junk yard motor then retired it al because of fast oil change i even offer to do it before going there
you"ll be alright
i went to dodge company in hanover tranny was in limp mode they got it out i was happy then they told me engine had problems it never had they gave computer print out said broke piston or crankshaft i drove it home on last leg started checking out they disconnected my back 3 plug wires i know they did it
you"ll be alright
I dont know what they do for the "engine flush" but I am a firm believer in the transmission service. I have 2 Ford E250 vans where I work and I have the transmission fluid and filter changed every 30,000 miles, one is a 2000 with 178,000 miles and the other is a 2002 with 205,000 miles, both still drive like they day we bought them. I dont know if anyone has seen on of the machines they use to change the transmission fluid, but it is a big plastic clear cylinder with a piston , the old fluid on the bottom and the new fluid on top. One of the cooling lines is disconnected and the machine is put in series with the cooler so that the old fluid will go into the bottom, and push the new fluid in the transmission when the vehicle is started. Even after only 30,000 miles, you can see a big difference in the old and new fluid. I dont see any way that this can damage a transmission, unless there is something I am missing???? |
might blow tranny shift springs or dirt further into valveing one to many times . your playing russian roulette then rebuild valves or more
you"ll be alright
My father did put a Jasper reman in a Chevy Malibu too,the oil change place put in the wrong oil filter and it blew up.The rods were pounding and oil went out faster than putting the oil in.
Maybe there is a different machine that flushes the fluid out? I cant see any way that this machine can do any damage, there is no power applied to the machine, it uses the pump in the transmission to do the work and it does not force anything in or out of it. I guess I am lucky where I take our vehicles, they check the fluid in the rear differential every time. |
We had simular exprience with monroe muffler went there for an inspection sticker and told my wife she needed all kinds of repair for her van to pass so the failed her. Of course they didnt know her husband my self am a mechanic so i took the van the next day an confronted them showed them the paper that they gave her almost everything they told her needed to be fixed was a lie except a swaybar link that was bad so they fixed that for free and inspected the van because i threatend them with the better business bureu.
[IMG]http://[/IMG] |
