Old 11-12-2008, 12:46 PM
ChillyB ChillyB is offline
Question Best adhesive for use with KA Models' seat belt material?
Has anybody found a particularly good adhesive for use with the seat belt material provided by KA Models? It is great looking stuff but I can't seem to find any reliable method of gluing to itself. I've tried white glue, Microscale foil glue, and a couple of others.
Thanks in advance for your help.
Old 11-12-2008, 01:15 PM
vrossi85 vrossi85 is offline
ABSOLUTModeling
Re: Best adhesive for use with KA Models' seat belt material?
KA model seatbelt is really hard to glue onto something. I tried white glue but it has no use at all, then i think of trying double sided tape. It was good initially, but after sometime it also seems to keep falling off from the adhensive. But anyway i turned back to my reliable but sometimes (disastrous) super glue, which works well for me
Ro
http://absolutmodeling.blogspot.com
Current project
Ferrari 248 F1
Ferrari 250 GT California Spyder
Old 11-13-2008, 01:15 PM
Ferrari TR's Avatar
Ferrari TR Ferrari TR is offline
Not A Hoarder!
I've had good luck using a quick setting gel type CA ('super glue').
Test it with some scrap to make sure you don't get a white residue on the pieces near the joint, otherwise you'll need to try a different glue.
SCCA 7, The lost Z
Old 11-14-2008, 07:59 AM
janositamas's Avatar
janositamas janositamas is offline
Same for me, I simply use super glue that makes it stick within seconds, and the result is very good. Note that the KA seatbelt material has different sides, I always glue the side that has no pattern on it. Good luck!
Old 11-17-2008, 11:47 AM
bobss396's Avatar
bobss396 bobss396 is offline
Send a message via AIM to bobss396
Have you tried that craft store glue called Aleens or something like that? Pretty thick stuff and holds well, messy to work with, like a thick Elmer's glue. Another suggestion would be 5-minute epoxy.
Bob
Old 11-17-2008, 05:44 PM
Didymus Didymus is offline
Superglue worked for me.
MicroScale Foil Adhesive was just the ticket for attaching the belts to the seats. It's a non-stringy contact cement, so you can just coat the belt, let the glue dry, and press it to the seat. You don't need to risk a mess by coating the seat, too. Just one surface will do.
Ddms
Old 11-25-2008, 05:16 PM
RAUL ORTIZ RAUL ORTIZ is offline
http://bond-it.ecrater.com/
great adhesives
