ECM question
I heard that the 85 305's incorporated a knock sensor which squeezed a little more horsepower. I have an 83 however and i was wondering if it would be possible to add the knock sensor myself? Is it a separate sensor i'd have to get and/or would i need to get an ECM from 85?
![]() ![]() ![]() '83 Caprice Classic LM1 (truck) 350 swap. about 200HP, 305 ft/lbs..for now. -- 65,000 original miles --
Re: ECM question
No, you would require a completely new ECM, along with a ESC module and associated wiring. The knock sensor interfaces with the ESC module, which interfaces with the ECM. I think 1984 was the first year for ESC on a GM car, could be wrong.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1! 2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness! 1967 El Camino L79/M20 old school asphalt raper Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have. |
Re: ECM question
Personally, I'd go for a 1987 ECM from a carbed setup. There are a lot more available options for programming with the later ECMs.
Permanent seat assignment on the Group W bench... Automotive Forums Survival Guide |
Re: ECM question
I was looking at some old info and found the spec's for the 83 caprice 305 H engine...150hp @3800rpm, 240ft lbs of torque @2400rpm...quadrajet carb. the 305 S 175hp @4200rpm 250ft lbs of torque...with this engine you would have a good amount of power...this is the fuel injected version... |
Re: ECM question
. I'll post the link for anyone who's curious. http://www.youtube.com/watch?v=eFTIeLh7Nto P.S.- be warned for people like silicon who hate "big rims and those rubber bands they call tires." lol
Re: ECM question
Re: ECM question
i seen that one b4 but its ok but at idle it kinda sounds hollow. almost like he took the insides outta the cats and left em in. but i could be wrong and could be just the camrea sound. lol
2005 JEEP LIBERTY RENEGADE CUSTOM HIGH FLOW EXAUST CUSTOM INTAKE 1989 CHEVROLET CAPRICE CLASSIC FLOWMASTER CATBACK 305 V8 |
Re: ECM question
well I have to disagree with that location....I just checked that it is at the T stat goose neck points straight up ...a squeeze connector two wires yellow and black....sets directly in front of the air cleaner ...this is a 305 vin H engine 1983 ... |
Re: ECM question
A knock sensor will have one wire on it and that wire will be dark blue.
Re: ECM question
http://www.youtube.com/watch?v=2baaZJbltYw
1997 Jeep Grand Cherokee Laredo 4.0L 2004 Jeep Grand Cherokee Laredo 4.0L 1983 Caprice Classic 5.0L |
