Old 11-12-2008, 09:55 AM
4G4D Store's Avatar
4G4D Store 4G4D Store is offline
Send a message via ICQ to 4G4D Store Send a message via AIM to 4G4D Store Send a message via MSN to 4G4D Store Send a message via Yahoo to 4G4D Store
Steering Rack differences
Guys,
I have the ex 4dr with the power steering rack. Now that I have the b18 in there I'm thinking about swapping to the manual rack. Are there differences between any of the racks, gear ratios stuff like that?
1991 Sedan LX Auto (Auto2Manual / MPFI / OBD1 conversions complete)
www.naytontech.com :: youtube.com/naytontech
Old 11-12-2008, 12:13 PM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
Re: Steering Rack differences
I don't believe so. Just make sure you get the mounting brackets to go with it as well. Power racks are a little bit bigger than the manuals.
Tony
91 Civic Sedan DX - Stock 287k Miles
Old 11-12-2008, 12:44 PM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
You need to change the whole crossmember to do it. But its really pointless to swap one. Just depower the rack, lop the lines after adding a bit of fluid in them. The rack will feel exactly the same as a non power, I ran a depowered rack in my crx because it was all I could get ahold of at the time. Also you could just make some simple custom lines to fit the b18 PS pump. All that is different is the side of the pump it enters from.
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 11-12-2008, 05:59 PM
Tony's Avatar
TLD Member #1
Thanks Frodo...I had forgot that I did the swap on a EJ instead of one of my EDs...because both of them have manual anyways.
Frodo is correct though, with the lines looped, its the same. I felt no difference in steering when I switched to a manual rack, I just did the swap because I had gone through 2 power racks with looped lines and was hoping maybe a manual would last longer...I was wrong. Keep in mind this was racing on a dirt oval is why I was going through the steering racks.
Tony
