Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 11-11-2008, 06:03 PM
adombombz adombombz is offline
91 eagle talon, high idle, tranny stuck in 4'th
I just bought a 91 eagle talon tsi awd. I have some problems that i can't figure out. The first is that it idles around 2500 rpms then between 1500 and 2000 when warm. The other is that the Automatic transmission stays in the same gear, even when i use "L" or 2nd so it makes for slow take off but around 80km/s it seem to finaly be in the right gear. the overdrive and econo make no difference. I'v tried using a voltimeter to get codes from the tcu but i cant match it to anycode number. so what im wondering is if the 2 problems are related or separate, thanks for any help.
Old 11-15-2008, 10:40 PM
sacred neo's Avatar
sacred neo sacred neo is offline
Re: 91 eagle talon, high idle, tranny stuck in 4'th
definatly seperate problems. First check your tranny fluid for the stuck in gear. if not that then you are usually screwed and have to take it to a speciallist cause there is rarely much you can do besides the obviouse. I guess the only thing else for that is does the car shift into reverse?
the other problem is usually a mix of a couple things. which engine do you have turbo or non?
Kris T.
Avionics Tech for Composite Aircrafts
99 Eclipse With Plenty of Plans in the Making
Old 12-03-2008, 09:37 PM
It's turbo. It works in reverse fine as well as between 60 k/m to 90 k/m while in "D", "2" or "L". I checked the solenoids, changed the fluid and filter. I tested the tps, kickdown servo and everything else that was in the repair manual. I'm going to try hooking a obd-II code reader and see if that helps. I would change the tranny or rebuild it but I don't want to waste time if it's the tcu or somthing.
