Go Back   Automotive Forums Car Chat > Buick > Regal
Old 11-11-2008, 05:29 PM
stickz13 stickz13 is offline
white smoke and water comeing out the tailpipe
well my car was low on anti freeze so i put some in and it just started to shoot white smoke and water out the muffler what could it be please help. I am in the service and my only car.
Old 11-12-2008, 07:29 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: white smoke and water comeing out the tailpipe
Welcome to AF!!
If the water smells like antifreeze then you have a blown head gasket. That is probably why the antifreeze was low in the first place. Not a cheap fix unless you have some friends who are mechanics or you can do the work yourself.
Old 11-12-2008, 11:10 PM
what if it does not smell like anti freeze ?
Old 11-13-2008, 06:29 AM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Since you did not identify the year & engine, I assume you have a 92 Regal listed in your profile which has a 3.1 engine. If so, when this engine is overheated, it is common to develop a hairline crack in the head within the combustion chamber area. Never assume that a head gasket will solve the problem! You need to take the head(s) to an automotive machine shop for a detailed inspection.
Old 11-13-2008, 01:51 PM
yes it is a 92 but its a 3.8 engine .
Old 11-13-2008, 03:32 PM
HotZ28's Avatar
AF Moderator Elite
Blown head gaskets are not that common on the 3.8 (3800 - Vin L) however, I suppose it depends low long it was run without coolant. You need to do a coolant pressure test first. Most shops have the tool & knowledge to do this.
Old 11-13-2008, 07:18 PM
ok thank you very much
