Go Back   Automotive Forums Car Chat > Mercury > Mountaineer
Old 11-10-2008, 11:21 PM
mountainman1 mountainman1 is offline
rear hatch lock on 98 mountaineer
when i use the key fob to unlock the rear hatch...lately it takes more then a few times to get it to open....problem with hatch or key fob....you can hear the gate latch make noise....but the lever to open it won't work till you hit the fob a few tries...any ideas......
wayne
WHEN YOU SEE THIS U C THE BEST
Old 11-11-2008, 06:51 AM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: rear hatch lock on 98 mountaineer
I had similar symptoms. I'd unlock the doors but the rear latch didn't feel connected to anything, like when the doors were locked. I removed the rear gate trim panel, then cleaned and lubed the rear latch/handle mechanism. It's been working fine for about the last 8 months now.
-Rod
Old 11-11-2008, 08:47 PM
thanks Rod....i'll try that this weekend...never ending problems with her lately....
Old 11-24-2008, 07:59 PM
Sorry it took so long to get back...busy as a beaver here.....anyways...Rod...did as you suggested....to a T.....still does it...any other ideas for me to try...seems the ole Mountaineer is starting to fall apart on me....things starting to go wrong....fix one thing...then something else.....but i love the thing so i fix and fix and fix
Old 11-24-2008, 10:55 PM
shorod's Avatar
SHO No Mo
You may need to remove the latch mechanism and see what is or isn't moving. You may be able to see something that broken if you have the latch out and in your hand. Too bad it wasn't as simple and a cleaning and lubrication.
-Rod
Old 11-25-2008, 11:08 PM
i could only wish it was that easy Rod,.....seems like i'm having a bad streak going...then when everything is fixed...i'll be a happy camper again...i love the mountaineer...it's just the fixing i've been doing lately....but this to shall pass.....I HOPE...
