Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 11-10-2008, 11:16 PM
SuperNova76 SuperNova76 is offline
92' 5peed problem
I have a problem with the reverse. When I go to shift into reverse, it feels like there is no slot to shift into, its like there isnt even a reverse at all.
I was driving down the freeway and shifted into 5th and after about 5 seconds it popped out and make that loud grinding sound, and ever since my reverse hasnt worked. After about 20 minutes of messing with it, i found that if i hold it down like i am going to shift and release the cluth and press the gas it will let me slid into reverse but it wont engage untill a good bit of grinding.
After it engages, my shifter is literally STUCK in the reverse postion and i have to use my whole body weight to push it back out, all of my other gears are fine.
Any thoughts on the problem?
Miles=142,225
Non v-tec
Any help would be greatly appreciated.
Old 11-11-2008, 10:01 PM
H23A1Lude H23A1Lude is offline
Send a message via AIM to H23A1Lude Send a message via Yahoo to H23A1Lude
Re: 92' 5peed problem
When is the last time you had your tranny fluid changed?
1994 Honda Prelude Si H23A1
Me: Get new U-Joints, then your Ford won't suck as bad.
Him: Do I need o-rings?
Me: No you idiot.
Him: Sorry, I've never replaced an O-Joint before
Me: FAIL
Old 11-13-2008, 08:55 PM
I have no idea, I just bought the car a month ago and already a whole host of problems have arisn.
The transmission problem has settled it self, i went out the next morning to leave for work ,and it shifted into reverse with no problem.
Also the idle is very rough, around 550 rpm, i checked the plugs and they have oil around the threads but not on the electrode. The plugs are also very dark, too much build up id guess, i figure the car is going to need a good tune up anyhow.
