Old 11-10-2008, 09:36 PM
anthony651 anthony651 is offline
Lower Control Arm
I am in need of some help. I got the control arm off but the metal part part of the front bushing is rusted on where it connects and I can't get it off i have tried everything, WD-40, pipe wrench, vise grip, you name it i have tried it. so if anyone can help me i would appreciate it.
Old 11-11-2008, 04:09 AM
Woodie83's Avatar
Woodie83 Woodie83 is offline
Re: Lower Control Arm
Get some penetrating fluid like Kroil or PB Blaster, WD-40 is not a good penetrating oil. Also, heat will help, hitting it with a propane torch will heat up the sleeve at a different rate than the pin. That whole arm comes off with two big bolts, you might have better luck more comfortably standing in front of it, clamped in a vise. A chisel might be able to cut that sleeve releasing the rust seal or a Dremel with a cutting wheel, either way be careful not to cut a groove into the pin.
Worst case scenario: 1stChevyParts.com shows the part for about $60 shipped. https://www.1stchevyparts.com/partscat.html
Woodie
98 Metro and 06 Aerio SX
Don't waste your vote on one or the other of the Republicrats, vote for Gary Johnson and really do something for a change
http://www.garyjohnson2012.com
Old 11-11-2008, 04:26 PM
Well I have tried to take off the 2 bolts but I stripped 2 sockets trying to do so...
Old 11-11-2008, 05:39 PM
CoolasIce CoolasIce is offline
What brand sockets?
Old 11-11-2008, 06:33 PM
one was a snap-on and the other was a matco, but i dont think it really matters what kind i used
Old 11-11-2008, 06:39 PM
Scrapper Scrapper is offline
AF Premium User
see if you can get one at sears craftmans and mack tools all i use. and if you heat with hand torch anymore spray it while its hot it will suck the penatraiting oil in.
Old 11-11-2008, 06:53 PM
ya i seen what happens when you do it wrong and the bolt snaps off. i dont need that happening
Old 11-11-2008, 07:06 PM
AF Premium User
i didn't mean a big tourch use the little hand help propane just get little warm and spray when they do start to lossen up go back and forth on them.
Old 11-11-2008, 09:49 PM
doug7x doug7x is offline
I used a hand grinder & just ground away the sleeve. (my new arms came with a new sleeve...be sure yours do before destroying the old one)
Old 11-15-2008, 03:25 PM
I got it off i bought a map gas/oxy torch from menards and i just cut right through the sleeve and didnt even disturb the pin
Old 11-16-2008, 10:57 PM
AF Premium User
so you did use and hand torch and it worked for you? glad to hear it.
