Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 11-10-2008, 03:10 PM
kNoykos's Avatar
kNoykos kNoykos is offline
Question Problem with 1981 Caprice.
I have a 81 caprice. and this past week i was driving home in the dark and all of a sudden when i would press on the breaks my check engine light would come on and then my lights started to get dimmer. By the time i got home i barely had any head lights. when i shut my car off when i got home it didnt want to start. The next day my dad came over and jumped my car. it started up. That night i was driving and the same thing happened. but it was also making this little ticking noise when i would press on the break and hold it. it sounded like someone was knocking on my window but they werent.
if anyone knows what could be wrong PLEASEE let me know.. Im in dying need of a answer..
.:Krista:.
Old 11-10-2008, 04:07 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: Problem with 1981 Caprice.
I don't think the two problems are connected.
Check the brakes for mechanical issues. Also, check the electrical (charging) system. Sounds like the alternator is not working properly.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 11-10-2008, 04:14 PM
kNoykos's Avatar
well i just put a new alternator on just over a year ago.
Old 11-10-2008, 08:19 PM
kNoykos's Avatar
does anyone have any ideas why its doing this??
.:Krista:.
Old 11-10-2008, 08:26 PM
silicon212's Avatar
Confoundingly Lucid
Does not mean a thing. Check it. I've had an alternator suffer a spectacular mechanical failure less than a week after purchasing it.
Old 11-10-2008, 08:33 PM
kNoykos's Avatar
okay. sorry.. i have no idea about cars. i'll take it to autozone and have it checked tomorrow. and i'll let you know what i find out.
.:Krista:.
Old 11-10-2008, 11:24 PM
beat88ls's Avatar
beat88ls beat88ls is offline
like silicon said, i had a s15 blazer that ate alternators. in five years i replaced the alternator four times. i had to replace the alternator in my 88 caprice the day i bought it and had to replace the alternator in my 83 two weeks after i got it.
1997 Jeep Grand Cherokee Laredo 4.0L
2004 Jeep Grand Cherokee Laredo 4.0L
1983 Caprice Classic 5.0L
Old 11-11-2008, 10:20 AM
kNoykos's Avatar
blah. that sucks. well im taking my car over today so i'll have them check my alternator. cross my fingers!!!!
.:Krista:.
Old 11-11-2008, 06:22 PM
82CapriceClassic's Avatar
82CapriceClassic 82CapriceClassic is offline
so what was it?
i know sometimes when i start my car...the battery light comes on...then when i put it in drive and step on the gas it goes off and sometimes my flip screen will go off in the middle of drivin...im thinkin the 2 15s i hate in the trunk is drainin the power or something...or it may be the alternator
Old 11-11-2008, 08:44 PM
kNoykos's Avatar
ohh.. sorry uh i had it tested and when the lights on my car were off it was at 50 or whatever. and then when i turned them on and they checked it, it was at 23. soo he said i might have something wrong with the regulator in the alternator or something else.. im gonna take it back this weekend when i have someone to drive me to return it.. so im hoping it was that..
.:Krista:.
Old 11-16-2008, 04:16 PM
kNoykos's Avatar
well i took my alternator back to advance auto...they tested it right in front of me and it tested like 14.9v without load and when they load tested it it tested at 14.7v....this leads me to believe the alternator is operating properly. my boyfriend sanded all the electrical mating surfaces to ensure everything had a good connection...so could i have a ground problem somewhere?
.:Krista:.
Old 11-16-2008, 04:58 PM
silicon212's Avatar
Confoundingly Lucid
It could be a ground issue. Check the grounds between the battery and the chassis, as well as the grounds in the headlight wiring harness.
Old 11-16-2008, 05:25 PM
kNoykos's Avatar
ok i will do that...where are the grounds for the headlights located i do have one that will not work with low beams but when i turn my brights(high beams) on the both work...passenger side is the one that doesn't work on low beams.
.:Krista:.
Old 11-17-2008, 08:11 PM
j cAT j cAT is offline
if the grounds at the battery and on the engine are good I believe your alternator is defective...it may be that the windings of the armature [the thingy that spins inside the alternator] has issues.....at idle all looks good...thats why this is a tough problem for the rookies....to figure out...
obviously the connections at the alternator must be clean no corrosion...
on the head lights clean all pins and connections to the headlamp connectors....replace lamps if you have to bang them to get them to work
Old 11-17-2008, 08:56 PM
Sunbound85 Sunbound85 is offline
Interestingly I had the exact same 'dying head lights' on my Caprice once or twice. It was the stalk on the column that operates the brights, these seem to fail quite easily, mine ended up locked on bright, but for a long time if I tried to dip or flash my lights, poof out went all the headlights. One thing to note, you have an '84 by now those plastic connectors on the head lights will be very brittle, be careful with them, mine crumbled in my hand, but i was able to rig an electrical tape job, but I wouldn't advise that for long term reliability. Those plastic connectors are probably still available though, sealed beams are used on many commercial vehicles still.
A test I always use to test whether my alternator was doing its job was to disconnect the Neg battery post while the car was running, if the engine quit, something is definitely wrong with the charging system. Good luck with your electrical gremlins, it's a part of the joy of owning a vehicle that is 1/4 of a century old!
