Go Back   Automotive Forums Car Chat > Ford > Contour
Old 11-10-2008, 10:29 AM
quarterpaint2 quarterpaint2 is offline
coolant fan running to loud
I have a 98 ford contour that I recently replaced the radiator and water pump on. Since then the fan has run excessively loud - what can the problem be. Car seems to be running fine, but the noise is excessive
Old 11-11-2008, 02:33 AM
Davescort97 Davescort97 is offline
Escort guy
Re: coolant fan running to loud
Welcome to the forum. If you have just replaced the radiator and water pump I would venture to say the fan blades are rubbing against the shroud or the radiator. The motor doesn't have to be on to check them. Turn the fan by hand and look and listen.
Old 11-11-2008, 06:26 AM
Thanks for your reply,The fan that is running is the little coolant fan that kicks on and off - now runs constantly at a high level of noise. The repairs were done at a Ford Dealership, but now they do not want to talk about what could be wrong
Old 11-11-2008, 09:40 AM
1grouch 1grouch is offline
take it back and put your foot down.......check that the fan and housing are solidly connected to the radiator, sometimes they miss the lower mounts on that fan housing....I would pull the whole thing out (fan) and check, it is relatively easy may have bad fan motor
Old 11-13-2008, 10:56 PM
Escort guy
I totally concur with 1grouch. Take it back. Did you know the Ford Repair Motto is "Done right the first time, every time" Be assertive. Where I work the squeaky wheel gets the grease!
