Old 11-10-2008, 09:02 AM
mandyann77 mandyann77 is offline
'96 chevy blazer water pump issues, i think.
I have a 1996 Chevy Blazer and I have to keep it cause it is paid for, here is my problem. It keeps overheating. I changed the thermostat 3 days ago and it did nothing. I can't go 5 miles down the road without the temp gauge going to the almost to the red line. The heater blows out cold air all the time so I am thinking that the water isn't circulating and the water pump is bad, right.? Help, Please.
Old 11-10-2008, 09:19 AM
Leeann94astro's Avatar
Leeann94astro Leeann94astro is offline
Re: '96 chevy blazer water pump issues, i think.
More likely your heater core/radiator is clogged.
Buy some radiator flush stuff and follow MTs step-by-step here:
http://www.automotiveforums.com/vbul...25&postcount=3
Old 11-10-2008, 09:23 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Welcome to AF
First thing check coolant level in rad and for coolant loss.
If no coolant loss check for proper operation and or replace the thermostat.
MT
Old 11-10-2008, 09:29 AM
The coolant level hasn't moved in the radiator reservoir and I changed the thermostat on Friday.
Old 11-10-2008, 09:36 AM
Check the coolant level in the radiator, not the reservoir. Just because it's supposed to pull from the reservoir when low doesn't mean it actually does...
Old 11-10-2008, 03:48 PM
Thanks for the help., I will try flushing the radiator and go from there.
Old 11-10-2008, 03:59 PM
MT-2500's Avatar
AF - Advisor
Check the coolant lev in rad.
Did you bleed system after stat replacement.
Does heater have any heat brfore it heats up?
MT
