Old 11-10-2008, 06:01 AM
chickenstew69 chickenstew69 is offline
Question 93 buick park ave passkey bypass
After reading all the post in this forum about vats issues,and having being left stranded repeatedly,im making sure that all i need to do is read the resitance from my ket, get a resitor w/ similar resitance.At that point do I wire the resitor inline on one wire or do i wire it across the two vats wires coming from the harness(does the power come from the switch or is it powered from the harness).Any suggestions would be appreciated.The park ave only has 217000 on it and i sure would like to get another 50000 out of it
Old 11-10-2008, 07:10 AM
brcidd's Avatar
brcidd brcidd is offline
Re: 93 buick park ave passkey bypass
In your car - it is really easy-- there are 14 resistances GM used that design- measure the one across the key- then solder in the matching resistor across the two white wires in the orange sheathing- be sure and cut the wires and solder across the car ends, not the steering column ends- I've done it several times- get tired of that pesky security light- and trying to clean the resistor pellet- sometimes the easiest way to measure it is to insert key and with the two white wires cut- measure the resistance across the steering column ends..-- do it several times to get the best consistent reading....
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 11-11-2008, 05:52 AM
imidazol97 imidazol97 is offline
AF -Advisor
The resistors go across the wires coming from the connector and the wiring that's in the dash. The wires going to the lock cylinder are passive.
http://vats.likeabigdog.com/
This link may help with further reading. You don't need the exact resistance of your key chip. The 14 or so listed are the only ones used. Your combination of resistance needs to be within a small percent of the value--somewhere I have a list of the ranges the reader will accept. I also read that mostly the first several VATS resistances are used by GM rather than the whole group spread evenly by numbers.
Old 11-13-2008, 03:13 PM
Thumbs up Re: 93 buick park ave passkey bypass
thank for the feed back.the resistance 0n the key chip was 680,wen to radioshack ,got the proper resitorfound the leads,clipped wires then wedged resitor into the harness itself.car started immediately .with car running,took resitor out ,then shut off car. when i tried to restart, started the run for 5 seconds and die thing again. bent resitor into u shape, wedged it back in the connector, and taped it in there tight. have had no further problems w/security system.have fought other issues that were the result of vats sensor in ignition going bad .I just wish i had diagnosed this problem and bypassed the vats first, rather than the headaches I dealt with.
