Old 11-09-2008, 05:22 PM
duke_winchester duke_winchester is offline
Help with an oil leak
I have a 97 Grand Prix GTP, and for some time now I have had a slow oil leak (I usually have to add 1 quart between oil changes). The leak is somewhere on the passenger side, as oil gets onto the main drive belt and gets dispersed all over the passenger side of the engine compartment. I have replaced both valve cover gaskets, as well as the intake manifold gasket. It would be greatly appreciated if someone could point me in the right direction for this. Could it be from the oil pan gasket, the oil sending unit, or the oil filter adapter if it is getting onto the main drive belt? Thank you
Old 11-09-2008, 10:11 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
Re: Help with an oil leak
Take a look at the oil filter adapter where it bolts to the block. i think these are troublesom on the 3800's.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 11-10-2008, 09:49 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Since oil is getting all over the main serpentine drive belt check the timing cover gasket and crankshaft seal behind the harmonic balancer. Also, the oil pan gasket can cause a similar issue. Safely jack up the car, remove the passenger side wheel and the plastic splash guard in the way and do a closer inspection.
Timeslip 08/12/06
AF Community Guidelines
