Old 11-09-2008, 08:52 AM
jveik jveik is offline
problem with k1500
my 95 k1500 has been giving me trouble. it randomly will start sputtering while i am driving and the only reason it doesnt die is because it is in gear (manual tranny). if i have to stop at a red light it will die, but will start up right after that, albiet still sputtering. it seems to do this for maybe 5 to 10 minutes, then it might not do it again for another day or it might do it the same day again. i figured a fuel delivery problem. i thought it was the wire from the coil to the cap, because i had been tinkering with that wire, but i replaced that wire and it still does it. im hoping it's not the fuel pump in the tank cause that would be a pain in my ass. could it be a fuel filter or maybe a fuel pressure regulator? (i have no idea if it has one, i have never looked into it) any ideas guys? oh if it's any help, it has a 4.3 baby 350
Old 01-02-2009, 08:39 PM
dave727 dave727 is offline
Re: problem with k1500
Hi, Im a new member here and just saw your post. Sounds like a bad fuel pump. Have you messed with it yet? Dave
Old 01-03-2009, 08:08 AM
maxwedge maxwedge is offline
A990 racer
Lets move this to the 1500 forum below where it belongs, right?
Old 01-10-2009, 12:03 AM
eustice70 eustice70 is offline
almost every time i had a fuel pump go out in this style of pickup it quit and wouldn't start again only one time i had the luxury of driving one into a garage to change it i have changed a bunch of those fuel pumps if you unbolt the bed and jack it up then you are able to reach the pump while the tank is still bolted in the frame its a lot easier than messin around trying to drain the tank and what not.
Old 01-11-2009, 08:54 PM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
The TBIs have a fuel pressure regulator that sits behind the two fuel injectors. It's possible that is the problem, usually a faulty regulator results in poor fuel economy and performance or difficulty in starting the engine. I will warn you that from reading the repair manuals, the spring inside the regulator body is VERY strong. I would say if you cannot compress it by hand or otherwise, then you won't get it back together when you replace it. Of course, unscrewing the bolts enough to test this will probably ruin the gasket and thus require replacement, so fair warning...there's no turning back with this foray. Some replacement regulators include the whole upper TB piece, but will cost much more...might be worth the money in avoided aggravation and/or second trip to the parts store? Any others had experience with this replacement?
I'd also check for correct fuel pressure, your IAC valve, EGR valve, and vacuum leaks. Finally, non-OEM fuel pumps have a poor reputation for reliability, but I'd check the pump's electrical ground first for poor contact or corrosion.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 01-12-2009, 08:46 AM
mudrunner80 mudrunner80 is offline
I agree with jdmccright. I had a similar problem with my 88. Mine was everytime I turned left and only left. I thought my truck was possessed. It turned out the ground for my fuel pump was bad. Drilled a new hole and now runs great I hope your problem is as simple
