Old 11-09-2008, 07:05 AM
tubbydad tubbydad is offline
problem with wiring
i have a 1993 grand am se with 3.3 liter engine, and automatic trans. i recently took the instrument cluster out to replace some bulbs. when i put the cluster back in, the dome lights and dinger stay on with the key OUT of the ignition switch, also had to run new wires for the radio because of this. i had to remove the fuse from the fuse box to stop the dinger, and dome lights from comming on, so now neither work at all. i checked all the wires and am clueless as to what to try next. any help would be greatly appreciated.
Old 11-09-2008, 05:13 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Re: problem with wiring
welcome to AF !
Did the bulbs go out while installing the radio ?
If so you could have burnt out a modul in the wiring attached to the cluster. A real PITA!
1999 Grand Am SS 3.4 OHV
Old 11-09-2008, 07:34 PM
i had the car running, and when i put the cluster back in, the dinger started going. but i did think about that, and took the cluster out, and even out, the dinger, dome lights, and radio still acted the same was as when the cluster was in
Old 11-25-2008, 03:15 AM
hey zero, replaced the dash and harness this weekend, everything seems to be fine, it all works. strange thing is, the new harness is different in the fact it dont even have a dinger, lol. the dome lights and radio work correctly now. thanks for the help
Old 11-25-2008, 05:32 PM
Yeah if the power(battery) was not disconnected when you were installing or removing the cluster thats most likly when it fried something.
Glad you got it fixed!
