Old 11-09-2008, 06:42 AM
Saucy9 Saucy9 is offline
Car Audio Problem...
I recently accidentally ran my car battery down. I charged it up using a power pack which was attached for about an hour. When I started the engine everything worked fine apart from my radio, which is only a very basic CD radio - no changer in the boot or anything fancy like that!
When I attach the fascia there is no power at all, I have checked the fuse box and nothing has blown there at all - I checked every single one, just in case but they are all intact.
I cannot think of anything else that could be the problem - could anyone suggest anything else that maybe preventing the power from getting to the radio?
Many thanks
Old 11-09-2008, 07:56 AM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
Re: Car Audio Problem...
there are fuses under the dash AND under the bonnet (hood). A few units also have a small fuse on the back of the cd player. Sometimes a fuse can look good but still measure bad, get a cheap multimeter to check them. If it's not a fuse then the CD player may be damaged. How did the battery get drained ?
Old 11-09-2008, 08:34 AM
Thank you for your speedy response, I left my car lights on all day, which is how the battery drained.
