(update) Water pump vs heater core
Thanks again to everyone who has replied, I wouldn't have made it this far without you... So today I removed the water pump, with the intention of replacing with a new one. However upon inspection the water pump was perfect. The fins were perfect, no rust, the bearing was fine, there was no movement of the pulley, looked as good as new...cleaned it up, and put it back on(also brand new oem 195 degree t stat in there) filled the coolant back up and ran the engine without fan. Within 5 minutes the engine was at about 190ish and I had great heat coming from the defroster. Put the fan on and put everything back together. Temp gauge was staying just barely above the 130 mark, defrost was blowing cold. Completely at a loss here, I am quite certain the heater core is ok(zero signs of leaking), plus the radiator wasn't even getting warm...we put cardboard in front of the radiator and the engine got warmer, with decent heat. Now my brother in law who is the more mechanical of us thinks its the fan clutch blowing too much at idle keeping everything cool...does this make any sense? any other suggestions?
thanks! |
Re: (update) Water pump vs heater core
Can you spin the fan by hand? It should have a little resistance when cold. Or is it locked up?
98 Ram 1500 4x4 Flowmaster American Thunder W/super40 |
Thanks! |
Yes. Get the motor up to temp. drive around a little. Shut motor off and check the fan clutch when warmed up.
Feels the same after warming it up, same resistance, I did have to block off the radiator with cardboard just to get it up to temp. And I still don't understand the sloshing in the dash area, I mean once the motor is warm that stops and I get heat, so frustrating. Thanks again for your help! 99 Ram 1500 318 4X4 |
O K I know this sounds stupid, but trust me I swear it's true. Umpteen years ago I had a similar problem. I could get up to temp idling in the driveway but lost it as soon as I started moving. Changed the thermostat, checked the temp in the radiator and the readings were correct. The problem turned out to be the antifreeze. On the advise of an old mechanic (older than me) here was the fix. I was running straight antifreeze and it was cooling so good it would not keep operating temp. I drained it out and replaced it with a 50/50 mix and it fixed my problem. I can't say if it is your problem or not, but it's easy to do and what are you out by trying at this point?
good luck
HERS---> 2006 Grand Marquis GS (replaced my 1998 w/cracked manifold) HIS----> 2003 Dodge 1500 HEMI QC 4X4 |
I have to say it really sounds like there is air in the system.
Thanks! Leo |
the way that I clear air out is to open up the radiator cap and then start the engine. Get your revs up and let it run for awhile. the air should eventually come out the top. can do it over a couple days and check the level of the coolant everyday as well. Actually open up the cap and check the coolant don't go by the bottle.
Leo 99 Ram 1500 318 4X4 getting cold up here |
the antifreeze content of 80% and 20% water will make it run cold and make it hard the temp get up.you could try a less % of antifreeze that will keep it from freezing up but let the motor run hotter and build up more heat. as for the air in the system keep the rad full and it will eventually work the air out.i had a roadrunner with a 318 and lived in ohio back in the '70s. if i put a mixture of antifreeze any stronger than 70% antifreeze /30% water then i would have little heat and the temp gauge would stay around 1/8th on the gauge.at 70%/30% ratio antifreeze the temp gauge would stay at 1/4 on temp gauge.you might have to do like the trucker's do on 18 wheelers and run a 1/2 dam [cover 1/2 the rad with cardboard] on the radiator until you get the air out.
thanks for the responses...ok this keeps getting crazier... the coolant/water ratio is at about 50/50 right now. I took my buddies advice and after getting as much air out of the system as I could I still wasn't getting to temp, stuck at 130ish unless I blocked the radiator. We took the fan clutch out and it seemed a little rough, didn't want to move freely, so I decided to drive it without the fan...at idle for 20 minutes it got to 210 and the heat was good, got on the highway and the temp dropped to almost 130 and stayed that way for my entire trip(about 20 miles) and of course my heat got cooler. I just can't understand this. There is no evidence of the heater core leaking or being defective, it doesn't leak when I do get up to temp either. Please keep the suggestions coming, thanks to all!
Also, would the fan clutch be the same on a 2wd Ram 318? Leo 99 Ram 1500 318 4X4 |
the fan should be the same on the 2- wheel drive as the 4-wheel drive if both have a 318 in them. just wondering you didn't put a mexican made t-stat in it did you?
I honestly don't know now that you mention it, they said it was the OEM, but it was like $12 from autozone. Is that realy a problem? Would Napa be a better option? |
NAPA is a better option, but the stealer is best. After all this, I would get one from the dealer.And that will hopefully eliminate that as being the problem. Also make absolutely sure it is seated properly and facing the right direction.
