Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 11-08-2008, 05:25 PM
CoolasIce CoolasIce is offline
Wire to computer from transaxle switch
The switch on the transaxle, that is basically a neutral safety and reverse light switch, also has a wire that goes to the computer. I'm guessing it tells the computer whether the car is in gear, or in park/neutral, maybe to lean out the TBI in park/neutral.
Does anyone know why it is there, and what will happen if the connection is bad?
Thanks.
Old 11-09-2008, 08:51 AM
maxwedge maxwedge is offline
A990 racer
Re: Wire to computer from transaxle switch
Seems you answered your own question, the pcm needs to know what gear it is in for trans controls number one and to meet pcm programming parameters. In the future include the year and engine in your posts.
Old 11-09-2008, 09:23 AM
It's an '87 with a TH125C 3 speed.
Old 11-09-2008, 09:26 PM
JohnDD JohnDD is offline
My 95 Cutlass Supreme 3.1 L had a bad tranaxle position switch (all burned up inside) and the car wouldn't shift into 4th (Overdrive or whatever). RPM was always high and burned gas like crazy.
Replaced switch and all is good. Not sure if open/ shorted wiring would give same results.
