Old 11-08-2008, 01:42 PM
Blazin1's Avatar
Blazin1 Blazin1 is offline
Question 96 Cavi Gas Gauge
I have NO idea how to fix the gas gauge on mi wife's 1996 Chevy Cavalier. Do I have to replace the CLUSTER or is it something else? The problem I had is that I ran out of gas because the damn thing said it had a little over the Empty mark, so on my way to the Gas Station it started bogging and died as soon as I added gas it started right up though
Old 11-08-2008, 05:23 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: 96 Cavi Gas Gauge
It's probably in the sender, which requires you to drop the tank and spend several hundred dollars on a new module... running below 1/4 tank will cause the pump to go out much sooner, so if I were you, just tell her to refill at 1/4 tank. GM senders are usually off a bit... nothing to worry about if you let it go.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
