unable to check engine codes
1998 ford econoline e 150 4.6 v8 206k just purchused for a work truck. the check engine light is on, sometimes flashing. i tried to connect my scanner but it cant see the vechichle. ideas on where to start?
Re: unable to check engine codes
take it to auto zone or advance since the check engine light is on they can hook it up. may just be o-2 you can unplug o-2 see if it makes it run diffirent?
the autozone couldn't check them ether. I went home and discovered a blown fuse. replaced it the pulled my codes and made the repair. it was a loose plugwire.
huh if check engine is on around here they can do it. main thing you got it fixed.
