Go Back   Automotive Forums Car Chat > BMW > 3 Series
Old 11-08-2008, 12:33 PM
gismo3 gismo3 is offline
1994 318 IS Trunk Lock
My trunk does not open. The key does not turn in the mechanism. Tried WD40, no luck. I have access to trunk through back seats, does anyone know how to open from inside ?
Old 11-10-2008, 06:41 PM
Broken-wrench Broken-wrench is offline
Re: 1994 318 IS Trunk Lock
Did it EVER work? Sounds like you have the wrong key. I have a 1994 318IS myself. There is a valet key that comes with the car ( I bought my car new in 1994). That key won't work in the trunk.
Old 11-11-2008, 09:03 PM
The key worked before. I think the mechanism broke. Does anyone know how to open it from the inside and I will replace it myself
Old 11-14-2008, 11:20 AM
One more thing... Does the key turn with ANY resistance and do all the dead bolts work when you operate the key in the drivers door? Could be that the latch is in fact working and the deadbolts have failed to work keeping the trunk unable to open? Check all of your fuses.
Old 12-29-2008, 02:47 PM
thepictorian thepictorian is offline
Smile Re: 1994 318 IS Trunk Lock
hi i may be able to help you
if you have access to the inside of the boot pull off the fabric facia on the boot lid then find the boot lock actuator possitioned inthe center of the boot and pull it it should then unlock the boot.
one other thing it is common in most bmw's that the wireing loom on the passenger side of the boot where the wireing loom is atached the the boot hinge the wires get frayed stoping the boot from opening.
if i can be any more help to you contact me at [email protected]
Old 12-29-2008, 03:04 PM
rogeiro rogeiro is offline
I would drill the lock or call "unlock specialists". Once I have drilled ignition in 2000 ford transit and it starts on screw driver now lol.
Old 06-22-2010, 08:58 AM
vsLozitsky vsLozitsky is offline
Pull the carpet thing off the inside of your trunk and you'll see a metal rod going from the lock on top to the bottom.Pull it to the side and it should snap out of the main lock.Then you pull the rod up and you truck should open.No drilling needed!!
