Old 11-07-2008, 04:33 PM
karnovking karnovking is offline
Banned
Catalyst system efficency below threshold?
My 01 Odyessy is reading code PO420 Catalyst system efficency below threshold.
Can someone tell me what this means?
Old 11-10-2008, 12:55 AM
UncleBob UncleBob is offline
AF -Advisor
Re: Catalyst system efficency below threshold?
it means your cat is bad, most likely.
life begins at 10psi of boost
Three turbo'd motorcycles and counting.
Old 11-10-2008, 08:15 AM
shorod's Avatar
shorod shorod is offline
SHO No Mo
There are a few items that can cause such a diagnostic code. Check the following before condemning any one part:
  • Use of leaded fuel
  • Damaged HO2S
  • Malfunctioning ECT
  • High fuel pressure
  • Damaged exhaust manifold
  • Damaged catalytic converter
  • Oil contamination
  • Cylinder misfiring
  • Downstream HO2S wires improperly connected
  • Damaged exhaust system pipe
  • Damaged muffler/tailpipe assembly
  • Retarded spark timing
Does your van run fine, or seem low on power?
You should also search the Odyssey forum for the code to see if there are common causes for this code on your specific vehicle.
-Rod
Old 11-11-2008, 08:26 PM
Banned
yeah, it runs fine. I cleared the code. Have taken the van about 200 miles now and the code has not come back. so i'm now playing "wait and see"
