| Cavalier Problem Diagnosis Got a problem you can't fix? We can help. |
1997 Cavalier stalls at Temperature
Hello all.
I have a 1997 Cavalier, 2.0L 5 speed. It starts fine and runs well until it reaches running temperature, and then it sputters and/or stalls and must cool off before you can get it running good again. The computer is giving a code running lean. Does anyone have any ideas? It's much appreciated. |
Re: 1997 Cavalier stalls at Temperature
A bad ignition module can do that. Could also be a vacuum leak, low fuel pressure, bad O2 sensor, or bad MAP sensor.
'04 Cavalier coupe M/T 2.2 Ecotec Supercharged 14 PSI boost, charge air cooler, 42# injectors Tuned with HP Tuners Poly engine/trans/control arm bushings Self built and self programmed progressive methanol injection system |
