Old 11-06-2008, 10:36 PM
kjm6995 kjm6995 is offline
ticking from passenger side
i've got a 2000 blazer and there is a ticking noise coming from the passenger side floor area. sounds like the turn signal is sticking after use.I've replaced the relay to no avail. Possable signal switch bad? also the wipers give me a hard time when trying to clean the windshield. have to force to work. help......
Old 11-07-2008, 01:13 AM
03silveradoaby 03silveradoaby is offline
Re: ticking from passenger side
It's your multifunction switch. Turn signal lever.
2003 Silverado 4.8
10k HID low beam/6k HID highs
magnaflow exhaust
k&n intake
2/10 rockford p3 shallows, downfire box, 1800w kenwood amp oversized battery and alternator hawk brakes
22" Forte miami's with Cooper zeon xst 305/40/22
Old 11-07-2008, 07:57 AM
fuzzbutt fuzzbutt is offline
On your wiper issue..
I don't know if it applies to the 2000's but my '98 needed a new control board on the wiper motor at about the 6 year old mark. There was corrosion all over that board. After that the wipers worked great. You may just be able to clean it off but I had the dealer I just bought my truck from replace the board.
Old 11-07-2008, 10:38 AM
AJT1961 AJT1961 is offline
As the above poster said, the clicking is definitely from the multifunction switch (turn signal switch) which is a well-known problem on these vehicles. There is an excellent post in the "how-to" section about how to clean the multifunction switch. I just used those instructions to install a new multifunction switch on my 2000 Blazer and they are excellent -- no, actually a life-saver. They made what could have been a nightmare job into an easy and pleasant one.
