Old 11-06-2008, 06:11 PM
97warwagon 97warwagon is offline
Erratic idle
Hello, I have a 97 GTP that has 140k on it and has a problem at idle. the car has an erratic idle and will rev upto about 3k then cut out in park. if you take it out on the road it pull to yellowline through the gears at wide open throttle with good power. I have a newer fuel pump filter ,as well as newer plugs and wires. what do you think it could be?
Old 11-06-2008, 06:31 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: Erratic idle
Check & clean the idle air control (IAC). I assume you have checked for vacuum leaks.
Old 11-07-2008, 07:40 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: Erratic idle
Are you saying the car revs to 3k by itself, or will only rev to 3k or so in park when you push the gas pedal?
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 11-07-2008, 01:39 PM
grandprixgtx00's Avatar
grandprixgtx00 grandprixgtx00 is offline
Send a message via AIM to grandprixgtx00
Re: Erratic idle
yeah...theres something called a rev limiter. when your in park and rev your car, it will kick in at 3K RPM's. its there for a reason...
