Old 11-06-2008, 02:14 PM
bigsmellyman's Avatar
bigsmellyman bigsmellyman is offline
Headlight wiring diagram
Does anyone have a wiring diagram for the headlights for a 2002 cavalier? It's a canadian car. Started with DRL doesn't work. Now right headlight doesn't work at all. I have done some reading on the subject and it sounds like people have had problems with bad wiring. thanks
Old 11-06-2008, 03:39 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: Headlight wiring diagram
Should we assume that you already checked the bulbs?
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 11-06-2008, 06:11 PM
Classicrocjunkie's Avatar
Classicrocjunkie Classicrocjunkie is offline
Lifted GMT-360!
Send a message via AIM to Classicrocjunkie
00-02 Cavalier
Driver side
High Beam Ground = Blue
Positive = Dark Blue
Low Beam Ground = Pink
Passenger side
High Beam Ground = Pink
Positive = Orange
Low Beam Ground = Dark Blue
Please don't PM me with your J-body Issues. Post appropriately in the forums,
and I will toss my opinion in your thread if I have anything to help. - Thanks!
2006 Chevrolet Trailblazer
2010 Glastron GT 205XL
Old 11-06-2008, 06:14 PM
Lifted GMT-360!
Damn edit button still doesn't work with new firefox.
Disconnect your whole wiring harness from the main connector under the battery tray. Look over the WHOLE harness for nicked wires, corrosion, etc...
You should find something somewhere along the front radiator or under the battery tray.
Old 11-07-2008, 06:57 AM
Thanks for the suggestions. Will have a go at it tomorrow. Did I read somewhere that part of the daytime running light system is under the front fender?
Old 11-07-2008, 12:31 PM
Lifted GMT-360!
Mmmm..... not 100% sure. I have an 03 headlight harness and it has a resistor in the fender. The relay is inside the car.
I want to say no it doesn't have a resistor. Because our 00 sunfire at the shop doesn't have one either, but there are soo many different wiring harness between the cars. The
