Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse 2000+
Old 11-06-2008, 10:26 AM
johncole johncole is offline
Question Help Changing Water Pump On 2003 Eclipse
I have a 2003 eclipse GT that is running hot and the heat is blowing cold air. I changed the thermostat but it didn't help. Ther is no water in the oil and no steam coming from the exaust. There is a noise coming from the area of the water pump so i'm thinking that could be the problem. What do I have to take out to get to the water pump. I have severe Rheumatoid Arthritis and don't have alot of strength in my hands but can't really afford to have it done. Any pointers would be greatly appreciated
Old 11-14-2008, 08:38 AM
Sleepr awd's Avatar
Sleepr awd Sleepr awd is offline
Send a message via AIM to Sleepr awd Send a message via Yahoo to Sleepr awd
Re: Help Changing Water Pump On 2003 Eclipse
Should be tied in with your timing belt system, in which case if you can't do it according to the book, you wont' have a car and you'll be in a bigger craphole than you started out in. If you have it done, have the timing belt done at the same time since it won't be much more work.
Don't act like you don't love it.
503/2000
