Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon
Old 11-06-2008, 12:16 AM
Andrewhuffman Andrewhuffman is offline
Angry 2002 belt tensioner. PLEASE help.
i got the pulley - $20. i think i have to remove the ps pump, motor mounts and three bolts for the assembly. hut it appears that the old pulley is rivited on the tensioner. where do i get the assembly? how do i fix it? someone must know
GT2560r's, Nismo 615cc, ARP Head Studs, UD Pulley, SouthBend Stage5 clutch, 60mm TB's, Ash-spec Tune, Specialty Z 3" DPs, HKS intake,
Energy Suspension, z1 Drive Shaft,E-fan, Port/Polished heads, AMS Manifolds, HKS SSQV BOVs, Howe Radiator, RPS segmented LW flywheel, UR OverDrive waterpump pulley, Billion Thermo, z1 silicone hoses, Stillen gauge pod w/autometers, D&S rotors all around
Old 11-06-2008, 07:07 AM
das2123 das2123 is offline
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
Re: 2002 belt tensioner. PLEASE help.
Are you talking about the idler pulley?
2003 Dodge SRT-4
Old 11-06-2008, 11:12 AM
the pulley that puts pressure in the ps/ac belt.
Old 11-06-2008, 11:14 AM
The power steering pump is used to apply the pressure for the A/C and P/S belts. The alternator is used to apply the pressure for the alternator belt.
2003 Dodge SRT-4
Old 11-06-2008, 03:47 PM
wrong!!!! on the 2nd gen. there is a tensioner with a pully. i went to the junk yard and got one today, the whole assembly. i noticed that the stud that the tensioner pulley is on (not he tensioner) is a torques type bolt. the assembly still has to come off to replace it.
Old 11-06-2008, 10:59 PM
Ahhh, thats why I stick to the 1st gen section. PM me and I can send you some PDF files that may help you out.
2003 Dodge SRT-4
Old 11-07-2008, 01:59 AM
i figured it out, PITMFA!!!! you can just replace the pulley.
