Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 11-05-2008, 05:51 PM
82CapriceClassic's Avatar
82CapriceClassic 82CapriceClassic is offline
Next Question...Tire Size For 82' Box
whats the best tire size for a 82 box caprice? just starting to really get into cars...it has stock hub caps so i just need something simple...
Old 11-05-2008, 07:25 PM
mike561 mike561 is offline
Re: Next Question...Tire Size For 82' Box
I think the box caprices come with 205-75-15s stock but you can go up to 225-75-15s no problem on the same rims and it wont throw off the speedometer, i currently have 225-75-15s on mine, i like look of the 225's better than the 205s, makes it look more beefier
2006 Chevy Cobalt LS
Old 11-05-2008, 09:21 PM
mega420 mega420 is offline
Send a message via AIM to mega420
exactly my words. and i do belive that 225 is the biggest you can go with the stock rims. i personally would get a nice set of crager rims and stuff some 235's in the rear and 215's in the front
2005 JEEP LIBERTY RENEGADE
CUSTOM HIGH FLOW EXAUST
CUSTOM INTAKE
1989 CHEVROLET CAPRICE CLASSIC
FLOWMASTER CATBACK
305 V8
Old 11-06-2008, 08:12 PM
j cAT j cAT is offline
205 is the stock size 215 is the option size...215 size is better on tire life and load...I used 215 75 r15 after the oem 205 worn out...never had any speedo issues...if you use larger tires be carefull you will get speeding ticket..I know of owners that had this happen speedo off 10mph in a 30mph zone....large rear tires did it....it did look good but it was expensive...
Old 11-07-2008, 03:53 PM
i always thought that if the tires were taller it will throw off speedo not width
CUSTOM INTAKE
FLOWMASTER CATBACK
305 V8
Old 11-07-2008, 08:29 PM
the 225's are what you have on your car now? btw how much did your tires run you?
i hate white walls on my car now...but im thinking of swapping those out and using the all black tires, like the tires on cop cars...but im undecided
Old 11-07-2008, 09:12 PM
463's Avatar
463 463 is offline
on my 86 it's got the F41 sport suspension with the 7" wide rims and the 225/70/15R/w/w (rop code QHK) and i have a set of 215/75/15/w/w for the ground grips on for the snow.
Old 11-08-2008, 08:57 AM
your tires size choices are to me correct... in winter you need narrow width tires...and the 70 tires are good in dry non snow conditions..load ratings are also good.
I always suggest that if you do not use the correct listed tire to check load rating and RPM'S /mile..
Old 11-08-2008, 10:13 AM
463's Avatar
463 463 is offline
the best infromation is on the drivers door sticker named the tire and air psi label
Old 11-08-2008, 11:08 AM
If i remember correctly i think they were a little over $300 for all four at pep boys for that brand i got (Futura GLS)
Old 11-08-2008, 05:41 PM
not bad price i paid over 900 for my michelins on my jeep
CUSTOM INTAKE
FLOWMASTER CATBACK
305 V8
Old 11-09-2008, 10:38 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Just one word I want to throw out about those Futura GLS tires through personal experience (apologies to mike561):
GARBAGE.
They will not last you two years and they can suffer catastrophic failure, at the least damaging your ride and at the worst, killing you.
I bought 4 of these in 1999 for my Grand Am. They were 255/60 R15. They were all replaced under warranty in early 2001, due to tread separation failures. Tire pressure was religiously maintained during the time they were on the car (as is still the case). The warranty replacemets suffered similar failures by the end of 2002, and two of them were replaced. The other two were thrown in the garbage, as I decided to cut my loss. The other two (the warranty replacements for the warranty replacements) also failed and I cut my losses on those as well. Of the failures, 3 of them were catastrophic, leading to bent metal and one near collision. All of the major failures occured at freeway speed.
3 of these tires found their way onto my Caprice by 2002 - two of them suffered two of the three catastrophic failures. There's still damage to my left rear quarter panel from one of the failures (which launched me across all 3 lanes of the US 60 freeway at Crismon Road in Mesa, at 75MPH in 2003).
Since then I've bought most of my tires at Discount (never had a bad tire from them), although the 4 I have on there now came from Pep Boys, they're Hankook tires and not the Pep Boys brand.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 11-10-2008, 07:21 AM
[quote=silicon212]Just one word I want to throw out about those Futura GLS tires through personal experience (apologies to mike561):
quote]
I guess these tires don't like the heat of the arizona desert..
I get my tires from costco. the total package is usually much cheaper than the other tire shops..Its been about 15 years and from costco I had one tire belt defect [caused vib's] and they replaced the tire for 30.oo..had about 50% wear..
they don't carry all brands,that can be a problem.....
Old 11-11-2008, 06:26 PM
paint is coverin the sticker on my door lol...i may need to shop around for tires..i might even try sam's club and wal-mart
college student pockets are the worst lol
Old 11-11-2008, 06:41 PM
bhw33191's Avatar
bhw33191 bhw33191 is offline
Send a message via AIM to bhw33191
When i was shopping around for tires i almost got ones similar to those Futuras. I liked the look of them however, the sears guy referred me to the goodyear assurance 215 75 tires because they were of a newer compound and better tread pattern. If you compared the two tires you could tell the difference was between 21st century technology, or 20th century technology. It's better to NOT sacrifice function over fashion as i always say.
'83 Caprice Classic LM1 (truck) 350 swap. about 200HP, 305 ft/lbs..for now.
-- 65,000 original miles --
