Go Back   Automotive Forums Car Chat > Ford > Tempo | Topaz
Old 11-04-2008, 09:46 PM
kgitter kgitter is offline
Angry 92 tempo no electrical power on ignition
Car has no elec. power when turning the ignition on no dash lights, radio or anything. Every thing is totally dead. Turn on the head lights and they are fine. Dome lights work annoying beep works when the key is in the ignition or the door is open. Jumping the selinoid with screw driver and the engine turns over with no problem. Fuses are all good. I don't think it is the ignition switch, have not had chance to test if there is power to the switch. Anyone have any ideas?
Old 11-13-2008, 07:42 PM
rhandwor rhandwor is offline
Re: 92 tempo no electrical power on ignition
I would check for a burned fuseable link look by the starter. On newer vehicles look at the power center by the strut tower.
Old 11-14-2010, 02:00 PM
fomoco1912 fomoco1912 is offline
check your ignition switch not hard to change, just have to remove the cover under the steering wheel and drop the steering wheel down to get to the switch also watch out they used security torx head screws on the switch.
