Go Back   Automotive Forums Car Chat > Mitsubishi > General Discussion
Old 11-04-2008, 01:11 PM
dmcollins57 dmcollins57 is offline
Intermittent Fuel Pump
Im having a proplem with the fuel pump on my mitsubishi van. The problem is when i go to start the vehicle it doesnt turn over, just cranks and when checking for fuel pressure there is none. When I add batter voltage to the fuel pump test terminal it doesn't turn on either. But when i go under the vehicle and hit the fuel tank with my hand it then turns on and I am able to start the van. But the thing is onces the van is running the fuel pump never quites. There is no loss of power or anything, only to when i turn off the van and attempt to restart it again after a while, the fuel pump doesnt work.
I originally thought that maybe there was a loose connection and that is why it would work when I'd hit the fuel tank but that doesnt explain why it wouldn't go out while im driving or hit a bump. Any help would be appreciated. Thank you.
Old 11-04-2008, 04:45 PM
CoolasIce CoolasIce is offline
Re: Intermittent Fuel Pump
I don't know why it starts when you hit the tank, but most cars have a fuel pump relay to send power to the pump. I'd replace it since it's easy to do.
Old 11-26-2008, 09:34 AM
mxmikie mxmikie is offline
sounds like the pump has 200,000 miles on it replace the pump
Old 11-26-2008, 10:22 AM
brcidd's Avatar
brcidd brcidd is offline
A fuel pump is a DC electric motor with brushes- it is like a blower motor- once they wear out, this is the exact failure mode- inability to start- but they will continue to run once "jarred" into action. Your fuel pump is on its last leg- so replace it-- I find that about half of those I test- will "jump" into action- heck I was a hero at McDonalds the other day- a guy with a pick-up- kept grinding away on his starter- I stepped over- whacked the bottom of his fuel tank- and it started- I told him to go get a new fuel pump- his is worn out. I knew a guy who drove his truck 6 more months this way- whacked his tank whenever it would not start- he finally let me change the pump- when he got the money.
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 06-22-2011, 12:11 PM
katreen87 katreen87 is offline
Hey even i have a similar problem with my car i am not sure what should i do. this weekend i take it to the technician.
Audi Parts
