Old 11-03-2008, 06:16 PM
ibanez0110 ibanez0110 is offline
transmission problem
i'm pretty sure this question has been answered a billion times, but i just want someone to tell me, to make me feel better about the situation. my transmission feels like it studders, or slips maybe when i get on it kind of hard. but only in first gear. sometimes it shifts hard too, not neccesarily when it's cold or hot...just kinda random. i've read some on these forums about "P1811" being a code that the transmission gives out. it seems like the symptons of this code kinda match what mine does. my car has 138,xxx on it. the guy who i bought it from said when he bought it, which was only a year ago...when he changed the oil and had the dealer swap fluid and filter, that's when it started doing it. if this is the case, what is the best route to fix this problem, and approximately how much will it cost, assuming i do all of the work?
Old 11-03-2008, 06:20 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: transmission problem
What year and model Grand Prix? If your GP has a 4T65E autotransaxle see the link below which will take you to our Tips & Maintenance section.
Click here
Timeslip 08/12/06
AF Community Guidelines
Old 11-03-2008, 06:38 PM
it's a 97 gtp
Old 11-03-2008, 07:11 PM
BNaylor's Avatar
Then you have the 4T65E-HD GM RPO Code MN7 transaxle. The procedure and guidelines in the Tips is applicable. Start by getting it scanned with a trans capable scanner and see if a P1811 DTC is stored or get the line pressure checked.
Also, are the symptoms the same with performance shift ON?
Timeslip 08/12/06
Old 11-03-2008, 07:17 PM
i actually don't know for sure, but i think so.
Old 11-03-2008, 07:38 PM
BNaylor's Avatar
If it is acting up with Performance Shift on or off them most likely a line pressure issue which would explain the hard shifts. See if the P1811 DTC is stored indicating the shift timing is off. When off the P1811 should set. It does not give a SES/CEL light but will store for retrieval with a scan tool/scanner.
Timeslip 08/12/06
Old 11-03-2008, 07:52 PM
the only thing is it doesn't do it all the time. it's only once in awhile, but it studders all the time...
Old 11-03-2008, 07:55 PM
BNaylor's Avatar
Studder or shudder or is it more like a misfire condition? Shudder can be caused by abnormal line pressure and/or the P1811 issue.
Timeslip 08/12/06
Old 11-03-2008, 08:38 PM
it's definately not misfire. it only does it in first gear...it feels like wheel hop...in the engine bay.
Old 11-03-2008, 10:43 PM
update: i went out for a drive, and put it down in "1" because someone said it has increased line pressure...and sure enough, it didn't studder at all. i actually broke my tires loose a little bit, which was nice because i've never done it in this car. so....i'm guessing this means i don't have enough line pressure in drive. what's the solution for this problem?
Old 11-03-2008, 10:58 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
I'm not sure that in manual low you have increased lin pressure. In fact with performance shift turned on, you also have increased line pressure.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 11-04-2008, 05:14 AM
BNaylor's Avatar
In manual PCS line pressure control operation is inhibited and line pressure goes to other values. Based on the symptom this is more like launch shudder. Same issue I had with my GTP over 4 years ago. I replaced the PCS solenoid and added a shift kit. And there was a P1811 (max adapt, long shift) DTC. Shift timing was greater than .65 seconds which causes the DTC to set and then commands maximum line pressure and disables shift adapts.
Timeslip 08/12/06
Old 11-04-2008, 06:55 PM
so i'm 95% sure the pcs is my problem. i know someone who will charge me $100 labor to take it apart and replace it. my question is, being as i have to pay for parts, how much is it for a new pcs? what about the tcc solenoid? gaskets/other parts?
Old 11-05-2008, 08:54 AM
BNaylor's Avatar
That is very inexpensive for labor considering the type work involved. Most tranny shops will charge around $500 and up just for labor. The PCS solenoid costs around $50. Get the Borg Warner brand. Since the transaxle side cover is removed you should get new side cover gaskets. Up to you if you want to replace the TCC-PWM solenoid or any of the two shift solenoids.
Timeslip 08/12/06
Old 11-05-2008, 08:04 PM
the guy who will do it for me said i should probably replace the tcc solenoid. how much is one of those, and the two shift solenoids? are they worth replacing? where can i get these parts?
