Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 11-03-2008, 03:23 PM
12inchesofpain 12inchesofpain is offline
Drivebelt won't stay on
The drive belt keeps comeing off my 95 eclipse gs. I have no idea what could cause this but my dad thought it was the bearing in the tesioner but he found out today it wasnt that. Please help
Old 11-03-2008, 04:14 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: Drivebelt won't stay on
Welcome to AF!
Are you talking about the timing belt? Did you do a timing belt change? When did this all start? Are you starting the car and it's coming off? If so, you may have damage.
We need a little more details in order to help you more.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 11-03-2008, 04:23 PM
No Im talking about the belt that gose to the power steering and the AC compresser.
Im sorry for the confusion.
Old 11-14-2008, 01:02 AM
sacred neo's Avatar
sacred neo sacred neo is offline
ok this should be an easy fix.
walk to the passenger side of your engine, so that you are looking at your motor sideways. now directly in front of the engine is the cam sprockets which are covered by the timing belt ( about 1 1/2 in wide), whish is covered by a shrowd or gaurd. just to the left of that is a pump with a pully connected to a different belt. this should be your problem belt. This pump is the power steering pump. if you look to the left (or towards the fromnt of the vehicle) to the end of the pump and the look down about 3 to 5 inches you will see a bolt head. tighten that bolt head until your belt is tight. tight means that you crawl underneath and find that same belt and press on it in either direction, when you get under 3/4 inch of play with firm pressure ( about middle between the hardest you can push with one finger and not pushing at all) then it should be fine.
