Old 11-03-2008, 11:51 AM
19hec68 19hec68 is offline
2000 ford windstar brake pressure switch
Can anyone help me? I have read several posts in forums as to why my #10 fuse blows and I understand that it might be the brake pressure switch. It's leaking fluid and I have tried to keep it clean but does anyone know how much the part costs and how do I replace it. It seems that autozone or kragens doesn't carry it. Any ideas?
Old 11-03-2008, 01:41 PM
northern piper's Avatar
northern piper northern piper is offline
Re: 2000 ford windstar brake pressure switch
it's a pretty easy repair. Pull the +ve terminal off the battery, unattach the connector at the base of the brake pressure switch. Using a box wrench (or ideally a line wrench) remove the old brake pressure switch. Install the new one. Reattach the connectors and you should be good to go.
Couple of other things. 1 get the OEM part from Ford. Not a ton of $$. 2 DON'T take the brake fluid cap off! That will just allow air to enter the reservoir and make the fluid stream out quick when the old switch is out. 3 Lay some paper or have a container on hand to catch any brake fluid that spills. If you have the parts and tools ready you can do it with minimal spillage. 4 make sure you refill the reservoir to the proper level with the correct DOT fluid.
Piper
2000 windstar 3.8
2010 honda pilot touring
Muskoka Canada
Old 11-03-2008, 06:56 PM
mundy5 mundy5 is offline
19hec68,
I actually have the original new design part from ford. I thought my yr had the old design but it was the new one. so i have it laying around. I'd be glad to sell it. I think it cost me $15 to buy it. pm me. I'm flexible on the cost.
2003 Windstar LX
1998 4dr Civic LX
Old 11-05-2008, 09:09 PM
wiswind wiswind is offline
I only had a couple drops come out when I replaced mine.
I have pictures that show the repair in the pictures that the link in my signature takes you to.
I do not think that they sell this part at the auto part stores.....I think it is still a dealer part......unless something has changed recently.
The good news is.....it is a cheap and easy repair.
Moderator for Ford Windstar room only
Links to my pictures, intended as an aid, not a replacement for, a good repair manual.
1996 3.8L Windstar
http://www.flickr.com/photos/4157486...092975/detail/
2003 Toyota Sienna pictures (not much there yet)
http://www.flickr.com/photos/4157486...781661/detail/
Old 11-07-2008, 10:41 AM
Thanks Norther Piper. Everything workout perfect. There was minimal spillage. My wife's minivan has 120,000 with few problems and I just don't like to see warning lights on the panel. It's all good now. This is a great Forum. I have been successful twice now. Thanks.
