Old 11-03-2008, 04:27 AM
bossman528 bossman528 is offline
How to replace power steering hose
I have a 1989 K2500 pickup. I think I have a leak in one of the power steering pressure hose. How do I replace it and how hard of job is it?
Old 11-03-2008, 08:00 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: How to replace power steering hose
Welcome to AF.
First thing find out which one.
Replacing is just unbolt old one and bolt up new one.
If the pressure hose you may need some big brake line wrenches or crows feet to unbolt and bolt the line back up.
Good luck
MT
Old 11-03-2008, 09:59 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
If it is the pressure side, and the pump is like my '95 (should be the same), the PS pump itself will have to be removed since there is not enough clearance on the back of the pump to unscrew the fitting and remove it. But to remove the pump the pulley will have to be removed to access the mounting bolts. Try to suck out as much PS fluid from the pump first to avoid a big mess when you remove the hose. Hope this helps!
On second thought, is that fitting on the back the return side? The other one on the side is just a push-on hose...so wouldn't expect it to hold a pressure...anyone?
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
