Old 11-02-2008, 08:16 PM
pithi69 pithi69 is offline
B18B1 OBD2 to OBD1
Hey fellow civicians lol, I posted this in the Integra forum aswell but I think I might get better luck here maybe, anyway..
I have a B18B1 out of a 96 Integra and im 100% sure its OBD2 now but I need to make this engine OBD1. How hard would this be? I know I have to change the distributor and I think I have to change the sensors too?
A distributor out of a 94-95 B18B1 will fit right? Because 94-95 is OBD1? What else do I need to swap?
Thanks for your help in advance!
Old 11-02-2008, 08:25 PM
Christ Christ is offline
Send a message via AIM to Christ Send a message via Yahoo to Christ
Re: B18B1 OBD2 to OBD1
All you need is the dizzy and to use an OBD-1 ECU/harness.
I'm assuming your car is OBD-1, so use your existing harness. Only hook up the sensors that you have plugs for, don't worry about anything else.
Use the OBD-2 injectors if you can get the plugs for them... you can wire the plugs into your existing wiring harness.. there is no benefit to this other than not having to buy new injectors if you don't already have OBD-0/1 injectors.
Recap: Change the dizzy, possibly injectors, use your existing harness, and OBD-1 ECU. You're good to go from there.
Honda-free since early 2009.
Current ride: 1996 Ford F150 4.9L (300ci) 5MT 4x4. Rednecks will win.
Old 11-02-2008, 09:02 PM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
*Edited for being brain dead*
The alternator plugs are different as well. The OBD1 is round and the OBD2 is square (if I remember correctly), but regardless they plugs are different. You can either use an OBD1 alternator, or swap the guts of the OBD1 alternator into the OBD2 alternator's housing. You'll only need to swap the part that the plug is attached to, it will be pretty obvious once you taken them apart.
For the injectors, there is a slight difference other than plugs. I have no idea what issues, if any, that there are with wiring the injectors backwards or not (positive and negative). I compared service manuals before, and the OBD2 injector plugs are wired in reverse from the OBD1 injector plugs. But I've never read about anyone having an issue with wiring them in reverse before, so it might not matter. But personally, I'd just use OBD1 injectors if you have them, for ease of installation.
*edit* This is info for an OBD2 engine into an OBD1 car only, not an OBD2 engine into an OBD0 car: You could just use an OBD2 engine harness if you wanted to use all the OBD2 parts (dizzy, injectors, and alternator), it's completely plug and play with your stock sub-harness.
Old 11-02-2008, 09:08 PM
Couldn't you just swap the plugs on the harness? Or is there a diff in the amount of pins or something?
Didn't know that part... about the sub-harness.. then again, how did you? We don't know what car he has, since he never told... although I've seen where diff harnesses have plugged in and been compatible. I can't remember which ones though, I think it was OBD-2 to OBD-1 (B18B in a EG or something similar).
Old 11-02-2008, 10:27 PM
Well i'm doing a swap into my 90 Hatch and also converting it to obd1. And also the B18B1 I bought did not come with a dizzy so I might as well buy a obd1 dist.
And yeah, i'm asking the same question now, couldn't I just use the OBD2 alternator + plug for the obd1 set up?
Old 11-03-2008, 12:20 AM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
You could also just use your stock alternator for your D-series...assuming you still have it. All you really need to do is drill out one of the holes on the mounting bracket one size bigger and use the nut/bolt from the D-series alternator.
Its perfectly capable of handling a B-series...because that is what I'm using right now.
Tony
91 Civic Sedan DX - Stock 287k Miles
Old 11-03-2008, 01:03 AM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
But yes you can use the plug and mate it to your harness. Also If the obd2 injectors really are backwards then I suppose im running mine that way. But then again maybe not. I followed the color codes on the pigtails I cut out of the car I got them from (obd2), its really not hard to get the service manuals for all of the cars and just look up the colors.
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 11-03-2008, 10:06 AM
CivicSpoon's Avatar
There is no Spoon
Crap, I wasn't thinking to clearly. But yeah, the OBD2 engine harness will plug right into an OBD1 sub-harness, and the opposite way (unless it's an OBD2 Civic instead of an OBD2 Integra). I guess this being the 4th gen forum, I should have assumed it was a 4th gen Civic
But yes, the alternator wiring should be the same (from OBD1 & OBD2), both have the same amount of wires, just different style plugs. Even most of the wires are colored the same. But clearly what Tony says to do would be the easiest way of all.
Old 11-03-2008, 10:15 AM
CivicSpoon's Avatar
There is no Spoon
I could very well be incorrect on this, but either way if it's working it shouldn't be a problem. My brain is freaking mush lately
*EDIT* - Ok. I did more think about this and I was wrong...sort of. The negatives and positives aren't reversed after all. But looking at the plugs, the wires are in different positions. If you're looking at the injector wires, towards the firewall, you'll see how the injector wires are. I'm not looking at the wires myself right now, so I'm just going to write out the basic idea of what I'm talking about. Every injector has a Yellow/Black wire, and then a colored wire. The OBD1 and OBD2 injector plugs have the Yellow/Black wires on the opposite sides. So one of the OBD plugs will have the Yellow/Black wire on the right side, while the other OBD plugs will have them on the left side. I suppose I may have been thinking about people who use OBD2 injector plugs and modify them to use OBD1 injectors (pulling out the blue plastic inside). In that case the negatives and positives would be crossed. But I was probably just not thinking
Old 11-03-2008, 12:02 PM
BLU CIVIC's Avatar
BLU CIVIC BLU CIVIC is offline
調整器
Send a message via MSN to BLU CIVIC Send a message via Yahoo to BLU CIVIC
he could just did what i did to but an OBD2 engine into an OBD0 car using and OBD1 ecu
The name's Adrian
1990 Civic HB Si - 265.7whp/223tq @9.2psi. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 296.3whp/230tq @1bar. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 185.8whp/139tq. Tuned on NepTune by J.Mills
2006 G35 Coupe 6MT - Stock
2011 CR-Z - Stock
Old 11-03-2008, 03:06 PM
So all I have to do is drop in the obd2 engine, swap a dizzy, alternator plug and ecu. Get a conversion harness for my civic from obd0 - obd1 and im golden??
I can even use the obd2 harness or would I need to get an obd1 harness?
Old 11-03-2008, 04:47 PM
You should use your car's stock engine harness and add/subtract/edit where necessary.
It's the easiest way... the thought that you could use the OBD2 harness was CivicSpoon assuming that you had an EG Civic. He's more into that forum :P
Old 11-03-2008, 08:17 PM
Oh btw my car is a DX so i'd have to convert to multi port and then I can cut/splice my stock harness for the B18B1?
Old 11-03-2008, 08:20 PM
Yep. Basically, follow the MPFI swap tutorial, put the harness on your engine, then put the engine in the car, bolt everything in, and plug it all up. Use the OBD-1 conversion harness, plug that up to your OBD-1 ECU, double check everything and start it up.
Obviously, there is going to be a lil more to it than this, but that's the BASIC idea of it. Those are the minimalistic steps.
Old 11-05-2008, 08:54 PM
Hey thanks for all the replies I think I got enough info to keep me motivated for now. I guess I need to read alot more though. Atleast you guys were better help then the Integra forum. That forums DEAD lol.
