Old 11-02-2008, 04:51 PM
dksob81 dksob81 is offline
Send a message via ICQ to dksob81 Send a message via AIM to dksob81 Send a message via MSN to dksob81 Send a message via Yahoo to dksob81
Dies when shifted into drive
I am working on a 1997 chevy Cavalier 2.2L. he replaced the ENGINE/TRANS and ECU. His car had the 3 speed trans and he put the 4 speed in it.
Well initially he called my because he was ahving a problem starting the car because the ANTI-THEFT SYSTEM was active. So I told him how to get that fix, with resetting/relearning the code and the car starts fine now, but whenever he puts it in DRIVE the car stalls, but in reverse it runs fine only when shifted to any of the FOWARD DRIVING GEARS does it stall.
Any suggestions ideas?
R.I.P. - 94 Jeep Grand Cherokee Limited 5.2L V8 Quadra-Trac, 3" Budget Boost, K&N FIPK Gen II (Cold Air Intake), FlowMaster American Thunder (Exhaust).
W.T.T.F. - 1998 Jeep Grand Cherokee 5.9 Limited - Deep Slate Pearl - K&N FIPK GEN II (COLD AIR INTAKE), Altezza Tails and Crystal Clear Front end light with HID Kit and NP242 Swap.
Old 11-02-2008, 05:00 PM
CoolasIce CoolasIce is offline
Re: Dies when shifted into drive
I was going to say your converter lock up solenoid is stuck, but that shouldn't be the problem since reverse is ok.
Old 11-05-2008, 02:48 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Could be a wiring problem, rocking the engine in the drive direction could pull a frayed/broken wire apart. Wiggle all the wires while it's idling in park and see if you can get it to die. Open the harness up where pulling it makes the engine die.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
