Old 11-02-2008, 04:13 PM
mdfan mdfan is offline
Bad High Beam Switch
98 Olds Intrigue: High Beams stay unless high beam level is pressed back a little. How do I get at the switch to change it?
Old 12-08-2008, 04:29 PM
oldblu65's Avatar
oldblu65 oldblu65 is offline
Question Re: Bad High Beam Switch
Replacing the headlight switch is somewhat complicated . The steering wheel has to be removed . If you feel you are competent in doing the repair , I'll gladly pm you the instructions .
Old 12-08-2008, 09:18 PM
harmankardon35 harmankardon35 is offline
i had a bad high beam switch in my old car...lows worked fine but when i flicked on the highs all my lights went out. Instead of pulling the steering column apart and spending $150 on a switch i just hooked the highs up to a small toggle switch. Worked well, not too ugly.
