Old 11-02-2008, 03:43 PM
Highbeamz Highbeamz is offline
Larger throttle body, worth it?
So I'm questioning if a larger throttle body is worth the expense? Does a 72mm throttle body increase HP or drop KR enough to be justified? Also, what's your take on the throttle body spacers? I know it adds more space between the S/C and TB but would that gap prove to be worth the cost of that mod as well?
Since I'm adding high lift rockers to my 3.4 setup for next year (along with supporting exhaust mods and intake mods and the t-stat/plugs) which I think should provide a nearly if not totally knock free motor. Would it even be worth my while to consider the throttle body or spacer?
Thanks!
2001 Pontiac Grand Prix GTP
14x,xxxkm's
Custom Cold Air Box w/ Airaid filter, Magnaflow Dual Tips, Quantum Tek 106 18" w/ Nexen N3000 rubber, Tinted Headlight Covers, Tinted Tails, Aeroforce Interceptor, 180* T-Stat, 2.5" ZZP Catted DP, Intense PCM, HID Conversion, F+R STB
Old 11-02-2008, 07:51 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
Re: Larger throttle body, worth it?
I only got a larger one bacuse my MAF went out and either a high flow stage 1 t-body for 199.99 or a replacement MAF for 119.99. I decided to get the T-body, I didnt notice any performance increase, but it might have lowered KR. Make sure you keep your MAF screen for your new t-body or alse order a new one from ZZP.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 11-03-2008, 08:38 AM
BNaylor's Avatar
BNaylor BNaylor is offline
In itself the 72mm throttle body doesn't do much but when combined with the other mods you have it helps. Main benefit is it improves power at the mid to high rpm range. It does help reduce KR. The same is applicable to the TB spacer. For a L67 engine it helps insulate the supercharger from the TB and reduces heat transfer. Also, the spacer blocks off the coolant ports since the throttle body has coolant flowing through it. Heat reduction helps reduce KR. It all adds up.
Timeslip 08/12/06
AF Community Guidelines
