Old 11-01-2008, 06:30 PM
car4685 car4685 is offline
Unhappy I have some codes; need to know what to fix??
I have the following codes on my 2001 Blazer;
P0128-Coolant Thermostat (Coolant Temp. below themostat regulating temp.)
P0101-Mass or Volume Circuit Range Performance Problem
P0151-O2 Sensor Circuit Low Voltage (Bank 2 Sensor 1)
So those are the codes I got from my scanner and the discription that it gave. I would like your help in telling my what parts I need to fix each code. Thanks a bunch.
Old 11-01-2008, 09:29 PM
Schrade Schrade is offline
Re: I have some codes; need to know what to fix??
Get a multimeter (you'll need one for house and car until the end of time). Go to a local mechanic, see if you can get them to print out ALLDATA, or Mitchell's online, diagnostic procedure for those codes.
If you go to a mechanic, don't let 'em start replacin' parts without doin' the diagnostics as recommended (unless you're rich, and then send me some cash?).
Old 11-02-2008, 08:32 AM
mike2004tct's Avatar
mike2004tct mike2004tct is offline
The P0128 would indicate the thermostat could be continuously open.
P0151 is the oxygen sensor (normally the heated unit is shot), but this could
also be due to the thermostat.
I'd replace the thermostat first, erase the codes, and see what happens.
It's not that exspensive, and I change mine every 5 years when I change the radiator fluid.
It's my opinion, don't take it personal.
'04 T&C,'01 Blazer ZR2, '97 Blazer, '97 Sunfire, '85 Vette, '79 Civic, 94 FLSTC
Old 11-02-2008, 11:40 AM
Alright..thanks
Old 11-02-2008, 11:54 AM
Maybe before replacin' anything, do some testing. It is ALWAYS, FOREVER AND EVER AMEN, cheaper to test FIRST. Not the American way tho'.
If you're gonna' pull the thermostat before any electrical testing, then TEST the thermostat. Thermometer, pot, boiling water, observe opening temperature.
And O2's have pretty specific codes - rich, lean, open circuit, grounded circuit, and they specify heated O2's also in the printout (HO2)
Test the circuit first. It's awkward, but cheap. Unless you're rich. Then send me some $?
