Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 11-01-2008, 06:30 PM
cmdahl cmdahl is offline
Question 98 Camry parking brake
This camry has 4 wheel disc brakes. I just replaced the pads and was looking for how the parking brake works. The parking brake will not lock in the up position. My experience with other parking brakes always had one set of drum brakes. I am wondering what I am supposed to be looking for.
Old 11-01-2008, 08:50 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: 98 Camry parking brake
The inability to lock your parking brake is probably a problem with the handle mechanism, not your brakes itself. I assume you mean that you cannot set the parking brake if the handle pulls up all the way. This then is an adjustment problem. It is not clear which problem exists in your vehicle.
Your parking brake is a set of drum brakes inside the hub of your rear rotors. You adjust them similarly to normal drum brakes.
Download at least the brakes section of the FSM from the following link and follow the procedure listed.
http://www.camrystuff.com/index.php?page=Gen4_Manuals
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 11-03-2008, 10:06 AM
Mike Gerber Mike Gerber is offline
AF -Advisor
In addition to what Brian mentioned, also consider a broken brake cable from the brake handle to the rear wheels.
Mike
Old 11-03-2008, 11:14 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Sounds like more info is needed on what you're experiencing. Handle comes up but doesn't lock? Handle locks but no actual braking? Brakes engage but not holding the car? More clues please....
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 11-03-2008, 09:02 PM
Will I know now what was wrong with the parking brake not locking. After taking the console cover off there was the problem. Sticky pop, yes sticky pop having been spilled down inside console by my daughter probably repeatedly over time. Finally keeping the lock part from working. I little cleaning and WD-40 all is well. Live and Learn. Thanks .
