Old 11-01-2008, 01:18 PM
gaguirre gaguirre is offline
98PA water pump
Has anyone changed a water pump on a 98PA? I have one boly on the far left side that is behind the pulley on the power steering that I cannot remove. Any suggestions?
Old 11-01-2008, 01:35 PM
ZiggyPA ZiggyPA is offline
Re: 98PA water pump
According to the Haynes it may be necessary to remove the power steering pump (without disconnecting the hoses) or to remove a long bolt through an access hole in the frame rail. Hope this helps
Old 11-01-2008, 01:36 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: 98PA water pump
You need to remove the two 13mm bolts from the PS pump and slide it aside. The one bolt behind the PS pulley is accessible from the holes in the pulley.
Old 11-01-2008, 08:15 PM
Re: 98PA water pump
Thanks for the help, I removed the PS pump via the holes in the pulley and had complete access to the water pump and all is running without any leaks.
Thanks again
