Old 11-01-2008, 12:18 PM
msusscle83 msusscle83 is offline
P0128 code
Hey guys,
Just had my check engine light come on and it is reading code P0128 - coolant thermostat. I checked my coolant level and it looks good, as does the fluid itself. My temp gauge also appears to be functioning properly. My mechanic cleared the code for now and said if it comes back then I have to change the thermostat and coolant sensor. Any thoughts/ideas? As always, thanks for the advice.
Old 11-01-2008, 12:54 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: P0128 code
P0128 - ECT Below Thermostat Regulating Temperature
This code is tripped when the coolant temp reading received by the pcm is below what it's programming says it should be (factory is 195 degrees F, +/- 10 degrees F). 95% of the time it's a bad thermostat.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
