Old 10-31-2008, 07:11 PM
1968 Pontiac's Avatar
1968 Pontiac 1968 Pontiac is offline
98 C1500 clutch/fan removal
I'm switching 305 engines in my 98 C1500 but can't get the clutch/fan of the old motor. I removed the four bolts which I thought held the assembly to the water pump, but none of the parts including the pulley would come off the water pump. Is there a trick to remove the pulley, fan, clutch? Thanks.
1949 Chevrolet 1433 (Canadian 1 ton cab and chassis single rear wheel pick-up truck)
1968 Pontiac Parisienne (rust free survivor)
1973 Buick Centurion (four door hardtop; engine will be donated to our 1949 1 ton truck)
1989 Chevrolet K3500 RC/LB (454 & single rear wheels)
1991 Chevrolet Caprice Classic (police cruiser clone)
1992 Chevrolet K2500 EC/SB (almost rust free daily driver)
1998 GMC C1500 EC/SB
Old 11-01-2008, 09:18 AM
maxwedge maxwedge is offline
A990 racer
Re: 98 C1500 clutch/fan removal
Check the how to at autozone.com, repair guides.
Old 11-01-2008, 09:27 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
The big nut on the clutch fan takes it off.
MT
Old 11-01-2008, 11:34 AM
Thx MT, I went to autozone but their instructions are incorrect as they are for the older style setup used for decades. I did get the pulley off; it was just stuck.
Old 11-01-2008, 11:42 AM
MT-2500's Avatar
AF - Advisor
You are welcome.
It gets tight.
I always whack it with wrench on it and whack the wrench with a hammer.
Good Luck
MT
Old 11-02-2008, 08:58 AM
I ended up taking of the complete assembly with the water pump. The wp looked to be a recently installed GM pump so I'll just install the whole assembly on the new motor.
Old 11-02-2008, 09:31 AM
MT-2500's Avatar
AF - Advisor
More than one way to skin a cat.
If you ever have to take it off they make a tool to help or most of them I hit the flat side on nut with a chisel to loosen it up.
A good air chisel will loosen them up in a few seconds.
Good luck
MT
