Old 10-31-2008, 05:09 PM
w.coast w.coast is offline
98 Taurus XL 3.0 Many small porblems
First time here and want to say, Thanks to all. Idle goes up to 1000 and down to about 500. Sounds like it wants to die. But not all ways!! Engine like came on awhile back with P1131,1132,1134. Did plug change #1 was burt down to a needle in the middle no porcalen left. Did change on all. Ran good but still idle prblem with missing. Anyone with any answers?? Thanks
Old 10-31-2008, 05:12 PM
Re: 98 Taurus XL 3.0 Many small porblems
Want to say that the engin lite is on now with P1131
Old 11-01-2008, 12:23 AM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Sounds like a misfire, probably due to a vacuum leak. Have you inspected all the vacuum lines? How about the intake air tubing? Was any service performed just prior to the issue starting that may point you in the right area to start your search?
-Rod
Old 12-13-2008, 05:06 PM
feroze feroze is offline
Do you mean "Check Engine Light" is this is your problem make sure you have good gas and gas cap closed properly.
Now you need to disconnect both battery cables and leave it over night. Minimum 12 hours and then clean battery terminals and reconect . This will allow the car computer to reset and then hopefully the problem is gone!
