Old 10-31-2008, 04:10 PM
tkpirrone tkpirrone is offline
95 Blazer fuel relay
I have a 95 S-10 Blazer with 100,000 on it. It has had the fuel pump replaced twice already. I keep having to replace the fuel relay about every ten to twenty starts. The relay gets real hot and eventually blows and the car stops. After it cool down abit or I replace the relay, it will start. At a loss on the problem.
Old 11-01-2008, 01:33 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: 95 Blazer fuel relay
Have you determined if the relay coil is failing or is it the high current side that's failing? Are you sure you're using the original part number relay? Have you measured the current draw of the fuel pump?
-Rod
