Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 10-31-2008, 08:21 AM
Rmasters3 Rmasters3 is offline
Transmission slipping
My daughters 2000 4WD Rodeo LS Automatic slips occasionally, usually when starting out on an uphill / slope. Otherwise I don't feel much problem, maybe a tad sloppy 1st to 2nd upshift, but that's very minor if not my imagination. The ATF and filter have been changed at least twice at 103,000 miles. Last change showed some browning of the fluid, but it didn't seem or smell burnt. If I accelerate pretty hard but keep it from dropping into passing gear, it also seems to be OK, just that uphill slope thing.
I'm guessing fluid level is the first thing to look at, and I have a pint of Transx additive I thought I might try. Any thoughts?
Thanks!
Old 10-31-2008, 05:12 PM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: Transmission slipping
your range selector may be dirty (common) see the faq's for more information.
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 10-31-2008, 06:17 PM
Found and printed the FAQ about the range selector. Other posts I have seen about the selector seem to deal more with shift problems than what I think I might be dealing with--a shudder. On an uphill slope from a standing start we get a pretty good shudder. I plan to check the ATF level and look at the range selector. Any other thoughts? Thanks
Old 10-31-2008, 07:38 PM
Isuzu Guy
check out the faq's for driveline thump or clunk.
-Ryan
Isuzu Moderator
Car Show Tips
Old 11-01-2008, 05:35 AM
This doesn't sound like a descripition of our problem. Ours isn't a single thump or clunk, but multiples- a shudder or judder as the transmission slips for a few seconds. We get forward movement but it's bumpy/jerky until it settles in. Thanks
Old 11-01-2008, 08:26 AM
Ramblin Fever Ramblin Fever is offline
Double check your ATF level, sounds low.
Just noticed my little overdrive pan gasket has started weeping again, which I don't understand, both these gaskets were replaced last year. Gonna double check my own level this morning. Mine's not slipping however, thank goodness.
Not quite sure what it feels like on this tranny when it does start to slip, but a shudder, etc doesn't sound right.
Is your daughter a harsh driver?
1997 3.2L V6 Rodeo
32" Yoko's, 16x8 MB Wheels, 2" lift, Brushguard, KC Fog's, Loadwarrior Rack
On it's way to 185k strong
2004 3.4L Tacoma TRD off-road 4x4 Double cab
32" Yoko's, Westin Bull-bar, KC Fogs 60K miles
Old 11-01-2008, 09:35 AM
She's a good driver and isn't pushing it. I test drove it for about 20 minutes and experienced it. The shudder/judder is pronounced, but brief. One thing making me look at the ATF level is that I didn't experience it except on the uphill slope. We changed about 4-5 qts. of the ATF a month or more ago and it's gotten worse/more frequent. I told my son-in-law to get 10 qts of some brand name High Mileage ATF and we'll take another shot at this.
Old 11-01-2008, 02:26 PM
Isuzu Guy
Ok. I've had this happen before. At about 55k, with 25k on the fluid, at about 53-55mph going uphill the tranny would jump back and forth gears. I took it in and they told me my intake manifold gasket was leaking and was causing the issue. It sorta fixed it. So since it was still happening, I decided to have the tranny flushed, thinking maybe the fluid was dirty (or most likely a little low).
They flushed it and the issue has not come back after 31k (which reminds me I need to go to the dealer and have them drop the tranny pan and replace the filter this time 86k on the ticker).
My guess is that your fluid is a bit low.
-Ryan
Isuzu Moderator
Car Show Tips
Old 11-01-2008, 02:53 PM
We'll be changing the ATF soon, but not before checking the fluid level. I had changed the filter about 30K ago, that being the second time the filter had been changed. Will let you know what happens. Thanks for the help.
Old 11-02-2008, 01:57 AM
Yep, double check your level.
Mine turned out to be 1/2 qt low, thank goodness I checked it when I did.
1997 3.2L V6 Rodeo
Old 11-02-2008, 03:36 PM
Transmission (still) slipping
Changed the ATF again and went to great lengths to be sure it was topped-off when running, etc. No improvement. Fluid was brown, not black, although I am a bit suspicious of the color given it's had several fluid changes (about 4 -4 1/2 qts. each time) in the last few weeks. I expected clearer & redder. I put a couple drops on a white paper towel and it wicked out even, brown, no grit apparent, no separation of fluid, etc. Added a transmission additive called TransX, since I had some and we were at it. No improvement.
Removed, cleaned and replaced the range selector (very dirty and one adjustment mount bolt was loose allowing it some movement) No improvement. Tried a couple positions of adjustment but no change.
Changed the rear differential lube and added an anti-slip additive; again no change.
This thing shudders, judders, slips and misbehaves seemingly only when you accelerate hard from a standing stop, up a hill, etc., when there is some pretty good stress on the low gear. It's fairly brief, but very noticable-subtle it ain't. All other shifts & gears are smooth; normal to easy start from a stop, or from slow speed there's seldom any shudder.
I am beginging to suspect a weak motor or transmission mount-maybe pulling the selector in/out of gear. Looked at the engine movement when stopped, brakes on, in gear but nothing suggested major engine movement.
Old 11-02-2008, 04:19 PM
Isuzu Guy
The tranny will do strange this with a weak electrical system. Weak battery, or dirty ground points
-Ryan
Isuzu Moderator
Car Show Tips
Old 11-02-2008, 04:37 PM
FL 3.2L FL 3.2L is offline
I gotta agree with you about something going on in there due to the fluid already being discolored. My last partial fluid swap, at 15K, showed very good looking fluid. It wasn't quite the cherry red of the new fluid, but it was pretty clean. Is there any chance this truck is running hot?
'97 Rodeo LS 4X2 Dueler Alenzas 4L-30E 200K
'96 Jetta 249K
'97 TJ 156K
'02 VW Cabrio 70K
'03 E46 107K
Old 11-03-2008, 12:14 AM
Agreed, condition of fluid doesn't sound right, should be clear pink with that many atf fluid swaps.
Was hoping for the best for you, as that tranny's not that old.
But, doesn't sound good.
1997 3.2L V6 Rodeo
Old 11-03-2008, 12:04 PM
Consensus from a shop I completely trust and the transmission shop that first shop uses is the sprague is weak or worn and it's time to replace the transmission.
Now the question becomes how to go about this-buy used, buy rebuilt, call the dealer for a re-man, etc. Anyone got suggestions where a decent used unit could be had, or where a reliable rebuilt could be obtained?
The tranny shop I took it to said parts were getting very hard to find for these, can you steer me to a good parts place, and maybe we'll have him rebuild it. He's to get back to me.
Thanks
