Go Back   Automotive Forums Car Chat > Lincoln > Town Car
Old 10-30-2008, 03:33 PM
stealthspeed's Avatar
stealthspeed stealthspeed is offline
Air Suspension Problem
I have a 95 TC and it seems to sit REALLY high in the rear, and sag in the front. Is there a way to manually adjust the ride heigt or air bags. Also is there a noteable problem with this. Any help is greatly appreciated. Thanks
Old 10-31-2008, 06:21 PM
ErickTR's Avatar
ErickTR ErickTR is offline
Re: Air Suspension Problem
Air springs are operated by height sensors and they can be adjusted manually. their is usually one in rear and one on each side in the front.
Make sure they are properly connected, you may have to replace them. Not a problem finding then in the junk yard. They are very easy to remove.
Old 11-01-2008, 12:30 AM
Towncar's Avatar
Towncar Towncar is offline
Also, you might need to replace the front springs to restore their original height. I don't see the front height specs. in the book, but I imagine if you check the rears (that spec. is readily available), the fronts should have the same fender/wheel.well/tire spacing as the rears.
Here's the adjustment details ErickTR mentioned for the rears:
1995 Town Car, Ride Height Adjustment and Specs.
-Steven
1996 Town Car, Cartier
Old 11-10-2008, 05:54 PM
junk yard doggie's Avatar
junk yard doggie junk yard doggie is offline
Ford made a shim kit for those front springs, I don't know if it's still available. A very common problem. No way that I know of to manually adjust the rears, without relocating the mounting points for the sensor. Fix the front springs, and that will probably solve the problem.
Mike aka JYD
