Go Back   Automotive Forums Car Chat > GMC > Envoy
Old 10-30-2008, 02:35 PM
ttrout ttrout is offline
Engine missing
2002 SLE just started intermitent missing. Will run smooth sometimes. Check engine light will come on when it runs bad but will then go off.Changed plugs and fuel filter as it has 97,000 miles. Im currently running injector cleaner in this tank of gas but it seems to have gotten worse. Any ideas, Thanks
Old 10-30-2008, 02:38 PM
maxwedge maxwedge is offline
A990 racer
Re: Engine missing
Get the code read it may point to a specific cylinder, post back. Did it miss before the plug change?
Old 10-31-2008, 09:25 AM
Re: Engine missing
Yes it was missing before the change, but only intermitently,now it misses all the time.The code indicates #1 cylinder, im guessing injector?
Old 10-31-2008, 12:13 PM
Schrade Schrade is offline
Re: Engine missing
Well, you can do an ohm test of the injector to see if it is at fault. Test it cold, and HOT, and compare against the other injectors...
Your code will store even when the light is out.
Old 10-31-2008, 06:22 PM
A990 racer
Re: Engine missing
Another problem could be a bad coil on the cylinder, for diagnostic purposes switch coils with another cylinder, clear the code, when it returns see if the misfire code points to the cylinder that now has the suspect coil.
Old 11-05-2008, 01:50 PM
Re: Engine missing
Going in , any preventive main. we should do while changing the injector?
Old 11-05-2008, 02:30 PM
A990 racer
Re: Engine missing
How do you know the injector is bad?
Old 11-06-2008, 10:26 AM
Re: Engine missing
ohm test, replaced #1 injector, runs great.Thanks for the help.
